Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3275 Questions View all
on/off button & back camera
On/off button sometime work, but sometime not. I must press hard and hold in order to make it work.
Back camera have difficulty to focus; mostly the time is out of focus.
Would like to know if this is a hardware failure, if if just something that need to be adjusted, or if it need a replacement.
Thanks,
David
Add a comment
1 Answer
Chosen Solution
David,
Just to be on the safe side regarding the back cam, you can try first a hard reboot and if it doesn't help, then a software restore.
But if you ask me, you have for sure 2 unrelated hardware issues:
1/ The audio and power control cable aka power button flat cable aka PMV cable of your iPhone 5 is starting to go bad. Soon it will stop working completely. This is very common for the iPhone 5, so much so that Apple has a program for repairing this issue for free even if your iPhone is more than 1 year old (check the Support section of their website or visit an Apple Store for details and eligibility), provided that your iPhone has not been tempered with before.
You can replace it yourself, but it is a bit of a PIA. Follow this guide. Be extra careful when prying the battery out. Pry only on the outer edge, never on the edge located near the logic board.
2/ The camera is probably defective too, and needs replacing following this guide.
The reasonable thing would be to have Apple replace the PMV cable (if eligible), THEN you replace the camera.
OR you can just go ahead and do both repairs in one go, since if you are replacing the PMV, you would already have gone through all the steps needed to replace the back cam. Look at the 2 guides and you'll see what I mean.
iPhone 5 Audio Control and Power Button Cable Image
Product
$24.99
iPhone 5 Rear-Facing Camera Image
Guide
iPhone 5 Rear-Facing Camera Replacement
Difficulty:
Moderate
45 minutes - 2 hours
Guide
iPhone 5 Audio Control and Power Button Cable Replacement
Difficulty:
Difficult
45 minutes - 3 hours
Score 1
Add a comment
Add your answer
david will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 90
