Engine stalls while running.
How do you replace the fuel pump on a 1998 Honda accord?
I've replaced my main relay last year and I am already having the same issues again. I think it could be a crank position sensor or fuel pump failing. Although it seems more of a fuel/electrical issue.
There was a recall on the ignition because the electrical contacts degrade. I would check to see if your car is part of the recall and if the card has had the recall done already. If not, that's most likely your problem. Happened to me 6 months ago.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,708
Can you tell us why you believe the fuel pump is to blame? There are hundreds of reasons vehicles stall while running.
by Tracy
