Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3313 Questions View all
best tool for standoff screws - stuck standoff screws
Hi,
Been reading posts on the standoff screws and removal of the screws when looking to remove the logic board.
I have been using a small flat head screw driver to remove these however I have been coming across some extremely tight screws which when using this method, I end up spending a good 30-60 mins removing two screws as the force needed to move them means the flat head driver slips,
Does/has anyone come across this problem at all? is there a tool that people use specifically for these screws? i've read about grinding down a phillips screwdriver to make it flat to get a good ground in all four connections. what do people think?
Thank you
Danny
Score 2
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Chosen Solution
Here's what you need:
iPhone Standoff Screwdriver Bit
Score 3
Comments:
You can also buy a standalone driver with that same tip. I have one and it is lightyears better than using spudgers or flatheads. Its worth the couple of bucks to buy one.
by
Hey! My standoff hex nut that I am trying to remove in my iPhone 6S is completely smooth! It does not have a slot for a flathead to fit anywhere. Any ideas?
by
Add a comment
Those things are extremely aggravating. I don't know why someone hasn't invented a screwdriver just for them
I have found the the round side of a metal spudger works really well when you have plenty of room and the pointed side works ok (better than a flathead screwdriver) in tighter spots.
http://www.mobiledefenders.com/metal-spu...
Score 1
Comments:
THEY DO! after a lot of digging around i found a screwdriver on ebay from china that is specifically for these stand off screws!! its incredable! best £10 i ever spent!
by
I worked on one for about 10 minutes with all of the different flat head attachments that come in the fixit kit and could only get it off after seeing this post and using a metal spudger. Thank you!
by
Add a comment
If you use a bigger flathead screwdriver, you should get more pressure? Or find a flathead screwdriver with a bigget bit so that it fills up the track in the screw?
Add a comment
I use the standard one you get in most repair kits and it works fine, just position it perfectly
Add a comment
Add your answer
danny will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 35
Past 30 Days: 209
All Time: 6,620
