Repair guides and support for coffee makers by Keurig including the K-Cup systems.
273 Questions View all
Keurig K40 not turning off automatically after 2hrs?
Not turning off automatically after 2hrs, how do i fix?
Add a comment
1 Answer
Chosen Solution
James, you did not tell us what you tried. Here is the way to set up your Keurig:
Programming Auto Off Timer Feature
Set the brewer to turn off two hours after the last brew.
1. Press the Power Button to turn on the brewer.
2. Press the black Auto Off Button to turn on the Auto Off Timer feature. The green Auto Off Light will illuminate. When the Auto Off Timer is enabled, your brewer will automatically turn off two hours after your last brew.
3. To disable the Auto Off Timer, simply press the black Auto Off Button again and the green Auto Off Light will turn off.
Hope this helps, good luck.
Score 1
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 68
Past 30 Days: 234
All Time: 12,055
