A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1690 Questions View all
Took off bottom cover now eject button doesn't work.
I too off the bottom cover to do some basic cleaning of my system (yes it was out of warranty). Everything works fine now except I can't eject the disc straight from the console. I can still power-up with no problems. Any ideas on a solution to this one? I can eject from the controller with no problems.
1 Comment
Does the button click when you press it?
by
Add a comment
1 Answer
Chosen Solution
The most likely cause of this problem is either that the bottom case is not totally snapped into place or there is also a small metal piece that goes from the plastic button that you touch to a copper pad on the optical drive board. If that metal tab is bent or broken then it won't be making contact and that will make it so it won't eject discs.
I'd check to make sure that it's snapped down all the way first, then remove the cover again and check that metal tab.
I hope this helps!
Score 2
Add a comment
Add your answer
Dustin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 670
