The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Question Closed
Why is my screen green & yellow?
So my iPad slipped off the bed & at first the screen was completely black but after holding down both the power & home bottom a couple times it came back, but now the screen is yellow & green, no adjustments to the brightness or hits on the back helps. & in order for me to see certain things on the screen I have to hold it at an angle because it looks like a shadow or its smudged. I took it to apple & they said its gonna cost me $249 to get it fixed because they will have to order a part. Please help I'm sure it's less complicated than they're making it. Or at least I hope so.
Add a comment
1 Answer
Chosen Solution
Hello,
It definitely can be less complicated, you may have a loose connector. However it honestly sounds like you broke the LCD, this can happen from dropping it of course. Still If you take it to Repair Shop (Read Reviews On The Shop You Choose 1st) It should be way less to have it replaced. I am sure they will be able to safely lift the glass and tell you whats going on with it.
Good Luck!
Score 3
1 Comment:
Thank you so much. I will look into a repair shop.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 339
