Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
After digitizer replacement, touchscreen doesn't work anymore
After i replaced my broken digitizer only the home button works - the touchscreen does not. Does anyone have a clue what that could be?
By changing the digitizer i cut through the old digitizer cable, not thinking about that there was still the battery connected - could that have caused the problem. If yes, how can i fix it?
Score 1
Add a comment
Chosen Solution
I would say it's a faulty screen you have recived just make sure cables are connected properly and disconnect the battery before you disconnect cables
Add a comment
If I don't disconnect the battery, is that will burn the cables?
Add a comment
Add your answer
kswiss0 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 361
