Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
574 Questions View all
Loudspeaker does not work after screen replacement
A customer came in with a Galaxy S5 that he had replaced the display assembly on himself. Overall, it actually looked like he did a fine job of it. However he said that after he changed the screen, the loudspeaker worked once, then when he turned the phone off and back on it stopped working and has refused to ever since. He still gets sound out of the headphone jack and over Bluetooth connection. He has tried everything (and I do mean everything, I asked) short of replacing the actual speaker unit with no luck. If a new loudspeaker does not solve this problem, what could be going on here?
Score 3
Add a comment
Did you ever figure this out?
1 Comment:
Sadly no...I have not seen the customer again either.
by
Add a comment
i have a phone in with this issue
Add a comment
I have a phone with this issue too replaced speaker and checked all pins and nothing
Add a comment
Add your answer
JonMark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,394
