Battery Charge problem since it fall on the water
Hello,
I have a problem with my iPhone 3G it doesn't charge the battery any more, i changed the dock and the battery and it still doesn't charge the battery.
Any idea, do you think the problem it's from the mother board ?
Thank's and have a good day.
4 Comments
First I cleaned the LogicBoard with a contact cleaner and after that nothing, no charge and you are right when i plug the USB charger there's no message like before "Charging" it simply not charge.
I'm going to check the fuse right now and i keep in touch.
thank's a lot
by Fajardo
ok, good luck
by markus weiher
I take it that there is Know fix to the fuse going but to replace the Logic board?
by Simon
i think some people have made a small jump of solder and very fine wire when small fuses like this "blow. have seen this for capacitors near connector 4. you could try googling the part if you've the fine soldering skills/equipment. I'm sure there is a site that has a list of all the small component parts and who made them, when I relocate the link i'll add it- if you fix it you could post back so others can learn!
logic board is a bit expensive to replace...
by pollytintop
