AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Questions View all
Question Closed
Not plugged to mac, but persistent green led light
hi,
a friend of mine brought me his old macbook charger ( the one with the T type connector), and it has a strange problem: it keep having the green led on even if it's not connected to the macbook. Plus i've checked the Volts and it gives 16,88v instead of 6.5 (or whatever). What could be the cause? thanks in advance
Add a comment
1 Answer
Chosen Solution
The voltage is fine. Use a toothpick to push in pins in and see if they are extending correctly. Especially check #3.
Pin 1 0 V
Pin 2 V+ @ 14.5 / 16.5 / 18.5 V DC
Pin 3 Charge control pin
Pin 4 V+ @ 14.5 / 16.5 / 18.5 V DC
Pin 5 0 V
Score 1
3 Comments:
i've tried to push the third pin but nothing, the LED still emits green light while unplugged from the macbook.
by
Did you test the charger cable (the 2 flat prongs) for a short while disconnected from the wall socket?
by
i've changed charger (i got a working spare one without connector) and it gives the same problem. Do you think it's due to a bad chip con the connector?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 193
