Click wheel connector detached
The connector fell apart, can it be weld or glued back to the logic board?
Topo Ceni, the connector can not be glued. You would have to find one and then change the connector by soldering a new one to the board.
Thanks! Can it be soldered with a Stanley Si30 soldering iron?
If you have a very fine tip for it, then yes you can use it. You also will need flux, desoldering braid and some fine solder....
Thanks for your advice! Sent the iPod to a technician, the iPod came back "working", because the wheel works fine for a few minutes and then stops working. Afterwards I can only reset the iPod (Menu + Select)
You might want to take it to your technician and have them recheck their work. also, try a different clickwheel just to be sure.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 131
