Apple's line of MacBook Pro laptops was intended for the professional and power users. The MacBook Pro line includes the MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", and the MacBook Pro 17" Unibody.
12123 Questions View all
Hardshell protectors ok to use?
I just bought a hardshell protector for my MBP, and was wondering if there are any issues with heat dispersion. It does have holes on the bottom for that purpose, and I didn't find anything in the Apple KB on this topic, but I did wonder whether these build up any more heat than normal, and if that has the potential to shorten the life of internal components?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
Get a monitor app which includes a temperature readout (I like iStat but that is purely personal). Run lots of apps on the computer for half an hour or so without the case on and see how hot it gets. I set Chess to play itself and run an app called grapher (in utils) and select a couple of the 3D example, this seems to send my processors to around 100% which should heat up the unit. You guessed the next bit, fit the case and repeat. Does the system get any hotter with the case on or does the cooling work OK.
If all good keep the case.
Score 2
Add a comment
Hello!
Ideally, the bulk of the heat disperses out the vents on the back of the machine (where the fans and heat sink are located). Does the case block these vents in any way? If not, I'd say you're fine. MacBook Pros just run hotter than many laptops, but as long as the airflow isn't impeded, it shouldn't be a problem.
Score 1
Add a comment
Add your answer
rkanes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 893
