Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Battery status says Service Battery
The battery status at the top left corner of my 17 says Service Battery. Charging is currently working fine, it also works fine without the A/C source at charge. Does anyone Macbook Pro 17 owner have this same problem? If so please kindly advise, thank you'
1 Comment
To help with diagnostics, download and run Coconut Battery and let us know your results. http://www.coconut-flavour.com/coconutba...
by
Add a comment
1 Answer
Chosen Solution
Could be your battery is swelling or damaged (I had one that got cracked - impossible to see until it was lifted out of the case) Damaged Li-Ion Batteries can cause fires do not delay finding the true issue causing this battery condition.
If this answer is acceptable please remember to return and mark it accepted.
Score 3
1 Comment:
Great advice, appreciate it very much, will check on it soon, thank you'
by
Add a comment
Add your answer
DYUEN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 305
