Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
iPhone 4: Black Screen and "bong" Tone/Noise
I tried to follow the tutorial to repair my iPhone 4's home button. Unfortunately the process was a failure because I am now experiencing a black screen and a never ending "bong" noise when plugged into a wall outlet.
Can anyone help/provide insight as to what's happened to it and if you think I can fix this, or should I just junk it for parts/repair on ebay? I don't know if this means the logic board has failed...
https://www.youtube.com/watch?v=BR9B-Fye...
Edit: I gave up. I took the whole thing apart and and tried to reassemble and the same thing occurrs. Not worth fixing this phone ($40 for a display really?) so I will be putting it on ebay for parts or repair.
Add a comment
Chosen Solution
Open back up and make sure the screen connecrors are fully pressed down and seeded correctly if still the same after that you will need to try a new screen.
Comments:
Thanks for your response. They are definitely seated correctly - I've reseated them a few times now trying to resolve this (probably only making my chances of getting this to work even worse). So do you think that I destroyed the LCD screen cable? I was pretty careful while I did it and there is no visible damage ie like a cut or hanging cable, so I'm pretty disappointed...
by
Add a comment
Try to do a hard reset on the phone... holding home button and power button at the same time.
Comments:
Didn't work, unfortunately.
by
Add a comment
Add your answer
John Cuppi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 277
