The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1434 Questions View all
Microphone and Speaker sound like static.
Hi, I just replaced the dock connector on a phone because I was told the microphone was having issues. After I finished replacing the dock connector I learned that it was not only the microphone but the speaker that was making a staticky sound, like if you were to put a phone next to a speaker or something. I'm thinking of replacing the speaker too but i'm not sure if this will fix it because whatever is happening is affecting the microphone too. Please come back with anything you think this might be, thanks!
Score 1
Add a comment
1 Answer
Did you take the grounding cable off the old connector it's located on the headphone socket screw hole.. And fit on the new one
Well, when I put the new flex cable in with the charging port and headphone jack and what not, the charging port ended up not working. So, I took the cable back out and put the old one in and it still didn't work, I changed them out twice each and finally got the original charging port to work but it was still making the static noise. With what I've told you do you think it could be anything that I've overlooked?
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 647
