13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
MacBook Unibody Model A1278 Got splashed by water, will not turn on
Unit got splashed with pool water and will not turn on. it seems that the battery is charging though.Apple want's $700.00 to fix!!!
What can I start to replace, bit by bit in the hopes to get the unit up and running?
Score -1
Add a comment
1 Answer
Chosen Solution
Water and electrons do not play well together
one of the drawbacks to an enclosed or integrated battery is liquid damage... you can't pull the battery easily.
I would venture that you have damaged the logic board but only examination will tell.
You might still be able to clean the corrosion or dry the board if you haven't already damaged components.
see What should I do after I spill liquid on my device?
If this answer is acceptable please return and mark it
Good Luck,
N.
Add a comment
Add your answer
Dennis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,939
