Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3220 Questions View all
Recovery mode Loop/Won't go thru iOS8 update via itunes
Hi Ive recently bought a phone with an "easy" fix, at least i though it will be easy. Phone was working on iOS 7 but guy told me that it keeps restarting all the time. You can use phone for like 5-10 mins and then it just dies. I thought maybe new update will solve the problem but unfortunetly what happened was that only itunes see this iphone but after downloading iOS8 via itunes and trying to update but it just freeze. Also in the middle of software download phone resets like someone would take out USB cable from pc and put it back in. Anyway it stuck in recovery mode(i can put it on DFU but it won't change anything) and keep doing same, even special rebooting programs dont help. I know that volume up/down wasnt working, maybe this cause that issue? Also im pretty sure that guy been messing with the screen as it has flickering effect and sometimes losing colors or weird lines appears on the screen. Touchpad and rest are fine. Ive tried nealy all common solutions for it.
Any ideas my friends?
Comments:
Checked today with diffrent screen and still same
by
Add a comment
Chosen Solution
I would check for a few things: board damage, screw placement, battery connection and voltage, and also see if there could be anything causing a short.
Score 1
Comments:
what im gonna check tomorrow is battery because i see that someone been lifting it and left a spot on battery and screws are randomly done. Ill let you know, thanks for giving me some extra ideas !
by
Add a comment
Solved, ive put everything from beggining with the correct screws and non magnetic screw was in wrong place on the mainaboard that might have been causing problems. Thanks tho!
Add a comment
Add your answer
nosferatum2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 186
