Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1647 Questions View all
Question Closed
Why isn't my Kenmore Refrigerator side freezing food?
I have a side-by-side Kenmore Refrigerator model number 106.51139210. It is turned to its highest setting (cold but not coolest) and it gets so cold that things are freezing on every shelf! The top shelf as well as in the veg crisper below! Freezer is at it's cold setting as well, but not the coldest, it's doing fine.
Add a comment
Chosen Solution
Deb, I don't mean to be condescending, but if it's to cold and set on the second highest cold position, try turning it down to a warmer setting.
Score 1
Add a comment
i have a KENMORE small refrigerant Modelr#564.94256400 punch a small hole in the place where ice be geting some of the ice off can i repair it do it yourself HELP
1 Comment:
I believe you are asking a question about your own problem and really not meaning to answer this question. The answer to your question requires more room than I can make through a comment. In the mean time what country are you in?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 263
