Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3236 Questions View all
Is battery easy to be replaced?
Is it possible to carry a backup battery on road and use a simple tool, like screwdriver to replace the battery for extended use? Thanks!
Add a comment
1 Answer
Chosen Solution
when you look at the teardown - you will see that the battery could be easily removed - but i would not do that. it looks fragile and i would prefer a mobile charging solution, i have a emergency charger that is powered by an AA battery - works great. this charger could easily modified to charge an iPhone
Add a comment
Add your answer
Kevin Chen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 895
