oil leaks I have replaced head gasket. where else can I check?
I have an oil leak leaving a spot size of silver dollar under the car. Have replace valve cover gasket.. where else might I check?
Score
0
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 129
Depends on where the spot is. The front , the back etc. I suggest that you clean the engine and after a drive check to see if you can see a new oil trail. Check underneath as well. Could be from the oil pan or the front or back main seal.
by oldturkey03
Mine had bad leak from under distributor. It is $2 o-ring to replace but because I neglected it, had to replace coolant line from the block to the cabin heater - it became weak being exposed to oil. This all easy job, for first timer (like me) was 2 hours including beer breaks.
by akpch
