Can I do a straight LCD swap?
I have a A1211 and want to remove the screen and re-install same on my A1226. Is this a compatible swap to attempt?
Bob Saylor, looks like part number 661-4238. That LCD is compatible with the following:"
MacBook Pro 15.4" 1.83GHz Core Duo (A1150) - Early 2006
MacBook Pro 15.4" 2.0GHz Core Duo (A1150) - Early 2006
MacBook Pro 15.4" 2.0GHz Core Duo (A1150) - Mid 2006
MacBook Pro 15.4" 2.16GHz Core 2 Duo (A1211) - Late 2006
MacBook Pro 15.4" 2.16GHz Core Duo (A1150) - Early 2006
MacBook Pro 15.4" 2.2GHz Core 2 Duo (A1226) - Mid 2007
MacBook Pro 15.4" 2.33GHz Core 2 Duo (A1211) - Late 2006
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1226) - Mid 2007
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1260) - Early 2008
MacBook Pro 15.4" 2.5GHz Core 2 Duo (A1260) - Early 2008
MacBook Pro 15.4" 2.6GHz Core 2 Duo (A1226) - Mid 2007
MacBook Pro 15.4" 2.6GHz Core 2 Duo (A1260) - Early 2008
Hope this helps, good luck.
Just make sure that the magnet that activate the sleep function when closing the display is located to the same side than your original display otherwise you'll lose that function.
Great information!
Thanks so much.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 121
