This Power Mac G4 has Mirrored Drive Doors.
94 Questions View all
What is the best method of removing scratches from the case?
I have purchased a PowerMac3,6, (MMD G4). The tower's case (not the doors) has a number of fine scratches, some are deeper than others. What is the best method to buff out these scratches while keeping the case's mirror-smooth finish?
Thank you,
Comments:
Wil, are we talking about the Acrylic sides?
by
Add a comment
Chosen Solution
Wil, fine scratches can be removed with a mild abrasive polish such as Novus #2, or Novus #3. Heavier scratches, such that you can feel with your fingernail, will require some elbow effort to remove with a bit of sanding and buffing. A series of grits (150,400,800) followed by a buffing wheel and available buffing compound, this should restore your case. Check on here to get an idea of how its done. Hope this helps, good luck.
Score 1
Comments:
Thank you. That is more or less what I was thinking.
by
Add a comment
Most Helpful Answer
I would honestly just get a new case, they are not that hard to instal if the scratches are that bad. If they are not some Pledge works great.
Please mark me up if this helps : )
Score 2
Add a comment
Add your answer
Wil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 317
