The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
214 Questions View all
What Is The RDOD? Can I Fix It Myself?
I have an Xbox 360 Slim, I've had it for 5 years and 4 months and have never had any problems with it what so ever. So...I turned it on the other day, I played on it for about 20 minutes then it just completely froze and there were a bunch of grey lines all over the screen, I turned it off, left it off for several minutes and turned it back on, after about 10 seconds that red dot in the middle of the power button turned to solid red and every time I turn it on it makes a strange noise like something is trying to start but something else is preventing it from doing so. Does anyone know what is causing this problem? (Could the problem be that I always leave my Xbox on a shelf? Or because there were some storm issues about 4 days ago and the power to the whole house kept going out?) My warranty expired about 2 years ago so is it worth paying for it to be fixed or should I just buy a new one?! Any advice will be appreciated!
Add a comment
1 Answer
Chosen Solution
kloosdaniel, the only thing that I can come up with so far is the RDOD (Red Dot of Death)Since it is not under warrant, check the optical drive. Apparently it can cause the RDOD :-) Also check Youtube for some decent explanations. This video shows one more trick you can try. If none of that works, open your console and clean the airvents properly of all collected dust and debris, change the thermal paste and try, or consider a reflow. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
kloosdaniel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 38
All Time: 1,908
