The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
137 Questions View all
Keyboard and trackpad stopped working, it works only in login. Help?
I woke up my computer the other day finding the keyboard and trackpad not working. The only button working was the power button.
When the login screen shows, the keys and pad works. The second I log in it stops working. Ive tried resetting SMC and PRAM, reinstalling Yosomite, nothing works.
Its clearly a software issue since its working in loging.
Any help please?
Now Im using wireless keyboard and mouse.
Score 8
Add a comment
Chosen Solution
On a machine this new I would be talking to Apple Support.
If this answer is acceptable please remember to return and mark it accepted.
Score 4
Comments:
Apple Support is difficult since they only operate with telephone calls. Im from Norway living in Thailand and dont speak thai, and they cant call me from Norway.
by
As a workaround connect a USB (doesn't have to be Apple) keyboard and see if that works. Also any USB mouse, and most Bluetooth mice/keyboards will work.
In a case like this the first thing to try would be deleting all the ~User/Library/Preference (.plist) files... many times strange behavior can be a damaged or corrupt preference. Did you recently add any fonts? Corrupt fonts also cause gremlins in the OS. -- Another quick way to find out if it's a corrupt file would be to create another user account --
by
Deleting .plist worked!! Thank you so much!
by
Didn't work after all. Stopped working after a couple of hours. Tried deleting downloaded fonts to, didn't help. Any suggestions?
by
Since it worked at first think about what you did (what programs you used) right before it stopped working. That program, or, that program's .plist could be corrupt, or causing the corruption. So try it again. You could even delete all the ~User/Library/Preference files - but you'll have to reset some of your application preferences. The easier way would be to create a new user account and try that for a day if it doesn't go bad in a couple hours you'll have verification that there's more than one bad apple (pun) in the bunch of apps you're using.
by
Show 2 more comments
Add a comment
Most Helpful Answer
press alt key five times
Score 7
Comments:
Wow!!! Thanks Sam. This worked. Can you define what was the problem and why it worked? Thanks.
by
Just as an information to everyone. My problem was much weirder. Just three keys on the right in each row were not working.
by
Had the same problem. The people at the mac store were absolutely no help! First ran an anti-virus and then did the alt key 5 times and works.
by
Press alt key 5 times when?
by
I’d like to know when to press the alt key too
by
Show 4 more comments
Add a comment
Try starting up in Safe Mode by holding down the Shift key on startup. This will disable any extensions that may have been inadvertently installed. If it does start up and run OK, you know it is a software issue. Also try starting up in repair mode by holding down the R key and run Disk Utilities.
Score 2
Comments:
It had the same problem i Safe Mode - worked in login but not after I logged in. Disk Utilities said everything look fine.
This is very wierd....
by
I am able to enter the password using safe mode by holding down the Shift key on startup. But when I restart it from sade mode, i am unable to enter the password as keyboard is not working.
by
Subhadip - you have an extension or a virus preventing you from logging in. Run a good virus program from an external boot drive or clean external system. Otherwise you will need to do a clean install.
by
Add a comment
All of these people and no answer i think i figured it out go to your system preferences. You will need to have a working mouse to get there obviously. Once your there go to Accessibility then click on the mouse and trackpad option. Once you are there you will most likely have ignore built in trackpad while using mouse. Uncheck that and your track pad should work now. You can disconnect your mouse and you should be good to go. At least thats what worked for me hope that helps.
Score 2
Comments:
What if trackpad is not showing up?
by
Add a comment
Creating a new user worked for me! I copied my desktop, documents, and downloads folder, created a new user, and pasted everything there :)
Score 1
Comments:
its work everyboooooody!!!!!
by
Add a comment
I had recently installed nvidia egpu driver(https://egpu.io/forums/mac-setup/wip-nvi...) which was causing the issue. Uninstalling it fixed the issue.
Score 1
Add a comment
I have had the same problem and I have find the solution... I was ready to restaure an old back up from time machin. To do so, I have before clean the desktop. I classified and removed all the desktop documents and restart the computer. Miracle, my macbook worked fine again. I think a document on the desktop was the cause of an interference with the keyborad and trackpad.
Add a comment
Had the exactly same problem with some macbook air 13" and it was finally hardware problem, replaced trackpad + flex cable and got fixed (did clean reinstall of everything software related and didnt fix it still worked in login screen)
Add a comment
no joke im being 100% honest , guys i dropped a pencil in class and it was very close to the substitute teacher that was a 10/10 she was so sexy, blonde, cute glasses,melon tits and an amazing ass with pearl white teeth she was 24 , anyways i dropped the pencil as she was helping a student and i took a nice sniff of her tight ass as i was grabbing the pencil and she turned around instantly cause i got a little too close and my nose touched her ass, i felt so dumb she just looked at me with an awkward face an started laughing, so i sat down and felt so stupid and one of my friend spencer was laughing so hard and she looked back at me literally bit her lips , as class was coming to an end she asked me to return the computers back and give them to the next class that booked them, as the class emptied out she told me to shut the door, she took of her pants and told me to get on my knees and eat her ass.. first thing i did was pull my pants down and shoved my penis inside of her ass i busted inside of her ass and she started to suck on my penis hard and i was eating her vagina out and told her to 69 me n she did... i couldn't believe it i busted a whole load in her mouth and she swallowed it, then she got up and begged me to eat her ass so i started shoving my nose and tongue in her ass violently and man it was the hottest ass ive ever seen, it smelt a little funny but man did i &&^& her ,, she ended up giving me her phone number and we hooked up 3-4 more times and she always wanted me to eat her ass right away then start sex and now i love eating ass she later told me she culdnt continue doing this because her boyfriend was becoming suspicious btw i was in gr 12 and was 18
Add a comment
Add your answer
Erling Hauge will be eternally grateful.
Past 24 Hours: 79
Past 7 Days: 401
Past 30 Days: 2,030
All Time: 52,585
