How do I brake the security codes on my iPod?
I have forgen my pass word on my 4th generation IPOD touch and I don t know how to brake the scearty code on my phone ,and I don t know how to get in with out a scearty code because I have forgen my scearty code that I put in.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
david, here is what apple says :"
You may be able to reset the passcode by restoring the device.
Connect the device to the computer with which you normally sync and open iTunes.
Note: If iTunes prompts you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes", below.
Right-click the device in the left column and select Back up.
When the backup is complete, select Restore.
When finished, restore from your most recent backup.
When finished, restore from your most recent backup."
If you do not have access to the computer you normally use to sync, follow these instructions. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
david will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 71
