The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3508 Questions View all
Does each part of the iPhone have a unique no.?
Does each part of the iphone have a unique no. that it belongs to the Manufactured device?
Add a comment
Chosen Solution
Hareesh7, if you are wondering if the parts from a particular iPhone, lets say 1234, can be identified as belonging to that phone, the answer is no. For Example, the display assembly has a number on it, but you can not identify that number as belonging to a particular phone.
Score 1
Comments:
Actually you can if you are Apple. Apple has been using this system for years, every broken phone is taken apart and analysed, so they can trace the defect to a particular supplier, assembly line and even the worker in person.
Recently Apple has been using this system to crack down warranty frauds in China. If the LCD, camera or battery serial number does not match manufacture or service records, Apple will deny warranty.
by
Tom Chai, is absolutely correct. Other industries have been doing that for years. The issues here is that the end user does not have access to the databank to check on which phone has what parts
by
Add a comment
Most Helpful Answer
Can you explain what you're asking for here. Almost every part has a unique part number so it can be replaced if broken. Are you asking if a given part is serialized? Many major parts are identifiable to a lot and in some cases unique identification as well.
Score 2
Comments:
What i need to know is... if an Iphone 5s with some number say 1234 Device is manufactured, The parts used in the phone can be identified by the part number that it is belonging Iphone 5s 1234 device?
If it is identified where can i find the Id for the Iphone and its parts? Finally how can i relate the parts with the phone?
by
Yes, its possible to trace parts. Again why are you asking.
by
Add a comment
Add your answer
Hareesh7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 111
