Do you stock the Logic Board?
My pad was dropped, screen lights up to dark blue. Needs a new board? I can not find the board in your parts list. I am looking in the wrong spot or do you have a part number?
I can't see your iPad so I cannot declare it but I think you have to check on digital screen first. and replace it. may be your problem will be solved.
if you wanna get new Logic board, you have to pay much money on it or you have to get junk iPad. it's speck has to be the same as yours.
if you can understand Chinese you can get cheap Logic broad from China though....
problem on my iPad 2
The screen does light up, but just to a very dim blue color. It seems to click a little when I swipe it after start-up. Perhaps it is the display, but it is not cracked and does display a little color. Is it possible that a connection came loose? doesn't seem likely, has anyone ever seen this?
well, by listing your iPad condition, i think my iPad has close problem to your iPad.
[image|448684]
I'm going to change display only. because dropping iPad can be strong reason of damaging your display but iPad is not PC it has hard disk. it is like a micro memory. So, even if you dropped logic board it might be OK that's why still you can see icons on iPad. if the board got damage, doesn't appear anything.
The problem is a little different. My screen just barely lights up, to a very dim dark blue. You can only tell it is lit up if you are in a very dark place. There is no change in my display, only just the very dark blue. Your display seem to be present, but distorted.
I see maybe your camera also has problem With recognizing light out side. Well When you dropped it I think several parts had some damage...when I find solution I will let you know....
Good luck finding a logic board nobody sells them as they are the iPad itself..
Your problem looks like a lcd problem if you replace lcd and still the same then you have damaged the graphics on the logic board.
Email jessabethany@gmail.com if it's board problems
Given that I can hear clicks sometimes, but can see nothing. Perhaps you are right and it is the LCD. The glass is not cracked and the input seems like it might work.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 143
Model #: iPad 2 CDMA A1397 64GB
by chrisnewitt
To be clear, there is no content to my display, I can only just barely tell it is on because it lights up just a bit. I can see nothing. Perhaps it might be the password screen. I can sometimes hear clicks when I tap the screen. If I hold both buttons for 10 sec there is a brief flicker in the display.
by chrisnewitt
