Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3230 Questions View all
Volume bar in control hub GONE!
So one day I turned on my phone and put on some music. I didn't hear anything. I looked and saw that the music was playing but there was no volume! I pressed the + button and the volume image came up but there was no bars indicating that the volume went up! I might have dropped it in water, but now I cant hear anything!! PLEASE HELP!!!!!!!!!!!!!!!!!!!!!
P.S I don't drink alcohol
Add a comment
Chosen Solution
This is rubing alcohol not actual alcohol you drink.
Changing the charging port will fix your problem
Score 1
Add a comment
Most Helpful Answer
Hello it's a common problem it's a fault with the charging port it thinks it in a docking station..
A simple clean with some ISO alcohol and a toothbrush in the charging port can fix this if it doesn't you will new a new charging port..
And this will 100% fix the issue
Score 1
Thanks for ur help bro, but i dropped my phone and its done for, anyway it was old
Add a comment
Add your answer
Jump St will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 58
