Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
526 Questions View all
Remove iSight and wifi card?
Is it possible to remove both iSight and wifi card physically from the MacBook Pro ?
(My IT department won't buy it if not :/…)
Add a comment
1 Answer
Chosen Solution
What you are going to need to do is remove the LCD assembly from the computer. You can also leave it on too, but you need to watch the keyboard and hinge cover. You can do it either way and it should work for you.
After you removed the display assembly(or left it on the computer) you need to work on gutting the LCD assembly to get it apart. Once you do this your IT department can remove the webcam.
However, this isn't really considered a "serviceable" part, so individual parts will be a pain in the rear to find unless it's from someone's used reject laptop, or a cracked display assembly.
As to the airport card, see this guide on removing it. That should get that out of the computer. This will also remove the Bluetooth from the computer, since it's a combined card.
That tear down does not show how to get into the screen.
Add a comment
Add your answer
sonyc91 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,161
