Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3266 Questions View all
Power button worked for a bit after replacement, rear camera and flash
ok so i brought a iphone 5 and its said power button doesnt work, but i opened it moved the flex cable and everything i also unclipped the metal bracket and reattached it, then it worked for about 3 weeks perfectly but then it got harder and harder, for the phone to respond to the press so i would have to press it harder then it stoped working so dont know what to do about that.
The rear camera would work sometimes same with the flash, this was after the power button fix, so it would work on and off for about 2 weeks then it just stoped working altogether, front camera works well thanks.
Add a comment
1 Answer
Chosen Solution
You need to replace the power button flex---the little plastic actuator wears down over time.
You may also have some water damage if you're having a rear camera problem. Replace camera to rule out the low hanging fruit first.
jessa
Score 1
Add a comment
Add your answer
Jordan Ockwell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 26
