Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
257 Questions View all
Dyconn Quartz 4 Bay HD Enclosure Cannot be Repaired?
I have a Dyconn Quartz 4 Bay HD Enclosure-WD Black External HDs. For the second time, with separate WD Black 2 TB drives in a Dyconn Quartz 4 Bay enclosure, I have gotten a message that the disk cannot be repaired. These disks were used as backup disks for a particular external HD that seems to be working fine. So far, no problems with other WD Black drives in the same enclosure, either as source or backup drives. OS is Apple Yosemite. Backup software is Carbon Copy Cloner. Don't recall a problem like this before updating to Yosemite, but didn't have this problem until after I had been using Yosemite for a while. Yosemite and CCC are latest versions. Question is, how to proceed with troubleshooting, given that the problem has shown up with two HDs that have not been used extensively or experienced any abuse?
BTW, I can access the data on the affected disks and CCC gives me an error message that certain files were not backed up.
Comments:
How do you have the disks configured?
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Clearly one or more of the disks are failing.
As to it being due to Yosemite: I don't see how as the low level services haven't been altered from Mavericks.
I would try testing the disks but dependent on how you have them setup this maybe difficult.
I happen to like Drive Genius as a good tool for testing things and it also can defragment a drive.
We use Western Digital FireWire & Thunderbolt external dual RAID'ed drives (dual 2 & 3TB) without any problems.
Score 2
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 223
