Why wont my laptop boot up?
Whne I try to boot my laptop I get a white screen, apple logo, and a spinning wheel.....
Add a comment
Chosen Solution
You can try a couple things:
  • reseat the RAM
  • Boot from the install disk or to target disk mode and connect another computer or boot from another drive to verify the drive
  • reset the PRAM
If the second option tells you the drive is bad, try to repair it via disk utility, but if that doesn't work then you can get a new drive here.
Add a comment
Most Helpful Answer
Thanks fo the tips.
Performed all sugestions. The results was repair/verify could not be performed in Disk Utility.
Afterwards I connected a 3.5 drive USB and performed the following steps:
Used the Snow Leopard install disk to perform an install to the USB drive.
When the install was completed, I coppied all the data & software from my orignal drive to the USB drive.
When that process (that took 3 hours) was complete, I reformatted the original drive and used Disk Utility to perform repair. I also did a verify to confirm the drive no longer had errors.
I am presently performing a new Snow Leapord install to the original drive. When that completes, I will copy the data and software from the 3.5 USB drive to the original drive.
I will keep the 3.5 USB drive as a back up. It will be good to have another boot drive available to troubleshoot future errors.
Thanks again for the input.
Score 1
Add a comment
Snow Leopard install failed.
Disk Utility revealed the drive has hardware problems that cannot be repaired. Therefore I will replace the hard drive.
Add a comment
Add your answer
LHicks07 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 800
