Power Steering Pump Leakage and Squeaky Noise?
i have a power steering pump leakage problem with my 2002 Honda Accord SE 2.3L 4cyl Automatic. Pump is pulling air into the system with low pressure making a annoying sound while steering. Also i think the pump oil assembly system has some kind of blockage. Could please suggest how to get it fixed & where i could get a genuine suitable pump.
2 Comments
Sounds like you need a replacement, unless you know how to rebuild those pumps. As for where you get a new one, that will depend on where you reside. Are you planing on replacing it yourself?
by oldturkey03
I have a 2007 Honda Accord with a similar problem. Pump makes noise constantly and leaks fluid as well. The first thing to know about Honda cars is that you must ONLY USE HONDA FLUIDS! Good thing to know after you've replaced the faulty pump.
Trying to get mine replaced as well. Will keep you updated.
by David Cave
