J.D. Corporation's JD Razor kick scooter was released in 2000 and became the most popular kick scooter brand in Japan. The JD Razor 2000 is a special-edition kick scooter that features an added wheelie bar and linear spring suspension. Often a strap and light are included with the scooter.
4 Questions View all
Why do my wheels wobble when going down a hill?
Whenever I go down a large hill, my wheels starts to wobble and shake uncontrollably about half way down the hill. This problem only happens going downhill and makes the scooter very difficult to control.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The JD Razor 2000's wheels become wobbly, it is probably at least one of two things: Flattened wheel round, or the wheel needs some tightening.
If the wheel is actually tipping the wrong way in its axis, you may just need to tighten the screws. Using a hex key, tighten the screw on either side of the wheel. If the wheel is still wobbly, it may need to be replaced.
Extensive and constant use of the scooter will flatten the wheels and take away their stability. Check your wheels' shape. If they look flat or squared on the rim, they are too worn down to ride safely and are most likely causing the wobbling. You should replace your wheels.
For help replacing the wheels on your JD Razor 2000, visit the guides:
Front Wheel Replacement
Back Wheel Replacement
If you suspect there might be an additional problem with the wheel, you can visit the JD Razor 2000 Troubleshooting page on the JD Razor 2000 device page
JD Razor 2000 Back Wheel Image
Guide
JD Razor 2000 Back Wheel Replacement
Difficulty: Easy5 - 15 minutes
JD Razor 2000 Front Wheel Image
Guide
JD Razor 2000 Front Wheel Replacement
Score 1
Add a comment
Add your answer
Eric Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 304
