Released on April 2014, this 16 GB Oppo Find 7a is the cheaper version of the Oppo Find 7. To distinguish the Find 7a from the 7, remove the back panel as well as the battery. There should be two serial number stickers that say X9000 where the battery lies flush to the phone.
After re-assembling the phone, why is the power button stuck?
I disassembled and reassembled the phone following the iFixit instructions, but now the power button is stuck and I cannot turn the phone on. How can I fix this?
Score 1
1 Comment:
faster duet very carefully
by
Add a comment
1 Answer
Most likely, you accidentally installed the button upside-down. If you install the button upside-down, it cannot make contact with the switch on the motherboard, and will not return to it's original unpressed length. To fix this, see the power button replacement guide.
Add a comment
Add your answer
James Kragh will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 23
All Time: 926
