Released in 2004 and identified by model number J3680. Compatible with Windows 2000 and newer software, and with OSX 10.3.8 and above.
6 Questions View all
How can I get my scanner to print a PDF?
The only files that are available are BMP, JPG, PNG and TIFF. Am I able to print a PDF? If so, does anyone know how I can do that.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
See if this answers your problem: Officejet J3680 scan to PDF option missing
Score 1
Add a comment
The most common cause of this issue is you may have the basic driver installed (which does not support PDF scanning), rather than the full feature software and driver installed. To install the full feature software and driver, go to the hp website:
http://h10025.www1.hp.com/ewfrf/wc/softw...
Then, select your operating system (windows xp, windows 7, windows 8, etc), click next, scroll down until you see "drivers", then select "download."
I hope this helps!
Add a comment
Add your answer
Marisa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 94
