Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB DDR5 Video RAM
326 Questions View all
Can I upgrade ram? apple says only 4 gb ram per slot
when I tried to id my macbook pro your id system didn't offer my actual model and processor. model is A1286 and processor is 2.6 Gz core i7.
when I checked apple's site they indicated that max ram for each of 2 slots is 4 gb for total of 8 gb. but your site indicated could be 8 gb per slot for total of 16 gb which I imagine would be much better.
and I have a 1 Tb internal hd original ... wondering whether performance would be any different with the hybrid drive you offer, assuming it can be installed in this computer.
also can internal ssd work in it?
and when might you anticipate larger SSD than 256 gb for reasonable cost?
Comments:
Can you give us your serial number so we can correctly ID your system.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
First, this is the Blog area not the store front. Here you will encounter knowledgeable volunteers answering questions based on their experience. Look at the score value under their name to get an idea of how that persons answers have been rated.
We need your systems info before we can answer your RAM question fully. On the most part Apple has updated many of the systems firmware to allow larger RAM configurations. Here's the Apple TN to check your firmware and how to upgrade it: EFI and SMC firmware updates for Intel-based Macs. Many systems now can support 16GB of RAM using two 8GB memory modules.
As to your HD question: A hybrid drive is much better than a straight HD drive as it offers a deep SSD based cache. So you gain the speed of the SSD but also get the size of a HD. I strongly recommend them. Seagate offers a nice unit. We have over 200 MacBook Pro systems in the field that have the Seagate SSHD units. I don't recommend using the dual HD setups any more given the issues they face.
As to your other question on larger SSD's: Surprising you can get a 2 TB SSD unit but it will cost you! (around $3,500 US). For now stick with HD's if you need space, I don't see the prices dropping for quite awhile.
Score 3
Comments:
thanks for your answers to all points. very helpful. EFI and SMC firmware are up to date. hadn't known about this site
by
Can you supply us your S/N (last four digits) so we can answer your RAM question.
by
Add a comment
Add your answer
yyweinberg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 209
