Distorted Video and Vertical Bands
I acquired a used Samsung LN40B530P7F display. The television had been working perfectly for several years. According to the original owner (my parents) the problem progressed slowly over the course of about a week and did not suddenly appear.
The television turns on and has good audio. The right side of the screen has three or four thick and distinct vertical bands in which no picture is discernable. The left side has video with crisp edges, but the color is malformed and washed out. The backlight appears to be on and lit uniformly.
I was told by someone who was knowledgeable that this was almost certainly a t-con problem. I purchased a used one and the issue occurs nearly identical regardless of which t-con is installed. I have reseated all three cables several times. I find it hard to believe I have two bad t-cons with the exact same issue. Given that I do have some video, good audio, and backlight, I find it hard to believe that the main board or the power supply is at fault. The screen has not been physically dropped or damaged in any way.
I'm looking for additional suggestions short of "throw it out". I'm hoping to fix this to give it to my kids for Christmas.
1 Comment
I cleaned up the tab but decided not to attempt a repair. Looks like this unit was part of the exploding cap lawsuit from a few years back. This unit just lasted longer than most.
by fromfacebook
