The first generation (KJ) Jeep Liberty, a compact 4-door SUV. Sold in both 2WD and 4WD configurations.
14 Questions View all
valve cover gasket on passenger side
Hello just wondering how would you go about changing a valve cover gasket in a jeep liberty 04 v6 passenger side mine seems to be leaking bad
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
ilya, from the service manual:"
REMOVAL
(1) Disconnect negative cable from battery.
(2) Remove the resonator assemble and air inlet hose.
(3) Disconnect injector connectors and un-clip the injector harness.
(4) Route injector harness in front of cylinder head cover.
(5) Disconnect the left side breather tube and remove the breather tube.
(6) Remove the cylinder head cover mounting bolts.
(7) Remove cylinder head cover and gasket.
NOTE: The gasket may be used again, providing no cuts, tears, or deformation has occurred.
Score 1
Add a comment
Add your answer
ilya will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 964
