Repair and disassembly guides and support for dish washing appliances.
232 Questions View all
The spray bar doesn't turn.
Frigidaire, Elecrolux Model # FDB710cs0 Serial # TH5189835
Score 1
Add a comment
1 Answer
Most Helpful Answer
Clean the spray arm
If the spray arm doesn't spin, remove the spray arm and clean it.
First take out the wire baskets by removing either a cap or pin at the end of the sliding tracks. Don't fret about a little water on the bottom of the tub. It's supposed to be there. It keeps the seals in the pump and in the motor assembly damp. If they dry out, they'll crack and leak.
The spray arm cap twists off with a clockwise turn, just the opposite of a regular screw. Twist ties, rubber bands and plastic and paper often show up in the spray arm. You might have to use a needle-nose pliers to pick them out. The pump usually sucks up most of this stuff, but if you hear a sudden loud grinding sound while running the dishwasher, something like broken glass might be stuck in the pump intake. Unscrew and remove the pump cover to check it out.
Score 1
Comments:
Add a comment
Add your answer
Ray Ray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 5,003
