Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
399 Questions View all
What bluetooth card I need
Hallo did anyone know what bluetooth card and adapter i need to make my mac have handoff?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
The pre-thin series of iMac's use a two board solution for the WiFi & Bluetooth services (Review the IFIXIT guides for your system here: iMac Intel 27" EMC 2429. Sadly there is no drop in part to enable Bluetooth 4 LE for your system. While some people have managed to hack a solution it is not very elegant. I'm sure a better solution will be worked out by some enterprising person just not available yet.
Here's a good source to follow: Continuity Activation Tool they offer the needed tool to enable handoff and reference the needed parts per system (hold off on the iMac stuff for now until the correct adapter is kitted with the needed card)
Score 2
Comments:
If this answer answered your question please remember to rate (score) and mark it accepted.
by
Add a comment
Thank you for the answer. As I saw from the guide the bt card and airport are in different sides and I don't understand what I need to change to work.
Comments:
Right now people are using a known part that Apple uses in other systems which is a combo board (one that has both WiFi & BT services in one part). So people are hacking their systems merging the two parts to the one combo part. As I stated above this is not a drop in upgrade unlike other systems which use an older combo board that only offered BT 2.1. Which is why you'll need to wait for now.
by
thxatzith - For future reference you posted a Comment in the place where only Answers belong. Please use the add comment link to the appropriate Answer or update your Original Question.
by
Add a comment
Add your answer
thomas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 186
