Model A1419 / EMC 2806 & EMC 2834/ Late 2014 or Early 2015 or late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 Processor / Retina 5K display
166 Questions View all
Which RAM is Apple building in?
Hi guys,
I'm interested in buying an retina iMac. I can't find out which RAM Apple is building in. Since you guys did a teardown, could you help me out here.
Thanks in advance.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
It uses: PC3-12800 (1600) DDR3 204-pin SO-DIMM
Per Apples TN: iMac: Memory specifications and upgrades
Score 1
Comments:
Thanks. I wasn't specific enough. Do you know which RAM exactly? Is it Samsungs RAM or Hynix like in previous versions of the iMac?
by
Apple buys so much memory it can't get memory from just one vendor. So you will likely see either one of these manufactures. I guess the question here is why does it matter? As long as the modules you are getting meet or exceed the specs it will work (exceeding the specs in this context is speed only - RAS & CAS)
by
Add a comment
It's DDR3 or DDR3L ?
Comments:
It's DDR3. Review my post above
by
Add a comment
Add your answer
WeitesgehendAnonym will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 667
