Model No. A1367 / 8, 16, 32, or 64 GB capacity
1321 Questions View all
unknown component in the bottom of the dock connector
Hello. I would like to know what kind of component that's what came off. It was close to the pitches of the speaker.
Thanks
Ciao. Vorrei sapere che tipo di componente è questo che si è staccato. Era vicino alle piazzole dello speaker.
Grazie
Add a comment
1 Answer
Most Helpful Answer
Is it metal? Are you replacing anything? It looks like it's a piece of foam from something you were trying to replace. Is that correct?
Score 2
Comments:
Thank you for your response.
I think it's a capacitor or an inductor, but the pins are damaged and can not weld it again and I have to replace it.
It was removed because the "technician" who preceded me glued to the motherboard with cyanoacrylate glue ...
Grazie per la tua risposta.
Io credo sia un condensatore o una induttanza, ma i pin sono rovinati e non posso saldarlo di nuovo e devo sostituirlo.
Si è staccato perchè il "tecnico" che mi ha preceduto ha incollato la scheda madre con colla cianoacrilato...
by
Add a comment
Add your answer
aintel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 70
