Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Touchscreen only works in low brightness!?
Hello all
Strange problem:
For the past 2 days my iphone 5 only works for 5 seconds upon unlock-lock. After that the touchscreen becomes unresponsive (i.e. ghost touches) and then does not work at all no matter what part of the screen you touch. Note that the hard buttons (volume, home etc. still work).
Then, I have to wait around 1-2 minutes for it work for 5 seconds again.
I have updated to ios 8.1, reset all settings, erased all content and setting and STILL the same problem.
Today however, it occurred to me to lower the brightness within the 5 second time frame AND IT WORKED! BUT only for 3 minutes, and with a few lags without any applications open. After that I opened safari, passport and messages and the touchscreen was, again, unresponsive.
What can the problem be?
Is it overheating? (although there are no signs of this i.e. not warm/too hot.)
Ken (not related to Ryu)
Score 1
Add a comment
Chosen Solution
Ok, first. Have you tried turning down the brightness, and seeing if that effects your touch? I wouldn't think it would. However I am a little curious. My first guess would be that you need to change the display assembly
Labor
iPhone 5 Screen Replacement
Parts
iPhone 5 Screen
iPhone 5 Screen Image
Product
iPhone 5 Screen
$34.99
Score 2
Add a comment
Only thing I can think of is that it's a hardware issue. Try a new screen.
Score 1
1 Comment:
Has the replacement solved the issue ? Same problem here and it looks like when there’s too much voltage or something it stops. Otherwise it works fine on lowest brightness setting
by
Add a comment
Add your answer
Ken will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 3,907
