Location for LG troubleshooting and repair.
16 Questions View all
LG Dishwasher Water not draining fast enough, OE error code
My dishwasher is 15 months old. When I first started using the dishwasher I noticed occasionally I would come back and see error code flashing on the dishwasher. I would always restart the cycle and it would complete with no problem. Starting this week, my dishwasher started giving an OE error code every time I ran it. I called a company to come out and take a look at it. The technician looked at it and told me that I needed to remove my floor in the kitchen so he could pull the dishwasher back and look at the drain hose. He told me it looked like the drain hose was clogged because when he blew on the drain hose he didn't see any bubbles. It would cost me $260 to fix the hose, plus my cost to remove the laminate. After he left I took the drain hose off of the connection to the garbage disposal and put it in a bucket then I ran the dishwasher. The water came out of the dishwasher into the bucket and filled it up. When I lifted the hose up to the height of the dishwasher drain, the water stopped coming out. Can anyone explain why it would drain when it was low but stop when I raise it? Is the technician right and I have a clogged hose?
Score 17
33 Comments
If it would be clogged, it would be clogged in any position. Have you removed the drain hose and taken a look at the pump? What model LG is your dishwasher? Any chance you still have factory or dealer warranty?
by
Yes, it is still under extended warranty.
by
At this point I haven't had a chance to remove the lament flooring. I'm planning on removing it this morning so I can pull the dishwasher out and take a better look at the drain line. I didn't think it made any sense that it would drain well is the line was low but wouldn't if I raised the line. I was thinking the pump might be putting out low pressure but I wasn't sure how to determine if that was the case.
by
Update: Called the original installer out to look at the dishwasher. He removed a excess drain line and moved the high loop from under the cabinet next to the sink to under the sink and it worked fine. When I called the warranty service company to look at the dishwasher they told me the drain line was clogged, that it wasn't covered by the warranty and that it would be $269. Bottom line: if it doesn't make sense, don't take the warranty repair mans word for it. Also, just because it have a warranty doesn't mean that they will fix it for free.
by
Warranty never worked for. In my case it was the pump. Warranty repair person says it is not pumping strong enough and it was not under warranty.
by
Show 28 more comments
Add a comment
Chosen Solution
I had this problem. Here is the solution. You'll need a compressed air source, even a small compressor.Remove the hose from the pvc trap pipe under the sink. (one screw) Using a blow gun, force air back through the hose until water gurgles up in the dishwasher. Then watch the water drain.! Works every time. Hose needs to be bigger, bad design. Technician will charge you big bucks for same procedure.
If that doesn’t sort you out, try some of the other suggestions on the Whirlpool dishwasher not draining page (note: the fixes there apply to pretty much all brands).
Good luck.
Score 23
38 Comments:
Jeff, you are a dead set legend. Was just about to buy a new one when I saw your tip. Hooked it up to my compressor with a garden hose reducer to drop the diameter down and its a goer. All done in 5 mins... Cheers
by
Wayne
Glad to hear it worked for you. Once in a while we crack their code. Well done!
Jeff
by
Jeff, I can get an air tank that holds 125lbs. Will this work? Also isnt there a check valve in the system that wont allow back flow or flush. Thanks Mark
by
Mark 125 lbs is more than enough. It won't take much. Wrap a towel around the hose where the air blower to optimize pressure going in and hit it. Not sure about the check valve thing but it worked for me. For about 3 seconds I got nothing and then it gurgled and the water drained. If there is a check valve, the clog may have been on this side of that valve and the air pressure may have just blew up the food clog enough to dislodge it. Fyi rice always seems to be a problem so clean your plates of rice, Stuff turns into concrete. Good luck!
by
Again do I just put it in the end that goes to the garbage disposal and blow back to the dishwasher. Thanks Mark
by
Show 33 more comments
Add a comment
There is a 'choke point' in the drain system.
If you remove the white nylon fitting on the left side you will see it.
It looks like a trap or siphon breaker with two large gray tubes and one smaller black one.
If you remove this part, examine it and clear it you can be sure the whole discharge tubing assembly isn't clogged.
In my case it only took two lemon seeds to stop the dishwasher with an OE error.
If you do replace the whole discharge piping assemble the problem will be solved (but only until it happens again).
C Affel
Score 4
7 Comments:
Compressed air will likely force the debris back toward the washer and clear it temporarily.
by
The smaller tube, the siphon breaker, will bleed some air when you try to test the discharge tube by blowing into it from where it meets the discharge pump. This may lead you to think the tube isn't clogged further on or that the pump is weak. Try my advice above and truly clear the rest of the discharge piping before buying anything.
by
Did you have to take the dishwasher out and turn it upside down to work on it?
by
I found this video on youtube. Is this the line to fix/clear?
https://www.youtube.com/watch?v=MRYv0Z_0...
by
The dishwasher stop draining with non-obvious clog. What I did was to lower the drain connection from under sink to a container close to floor and use quick cycle( as opposed to Normal) and it started draining and working fine now. When I examined the container with the waste water there was nothing obvious that could have clogged the pipe. So it must be clogging to a "choke point" that has some kind of sensor to tell the control stop proceeded. Anyway, just lower the drain
by
Show 2 more comments
Add a comment
I got the OE error too. Pulled off the drain hose where it enters the household plumbing and turned on the dishwasher on to drain.....worked perfectly.
The problem was not with the dishwasher, the plugged drain was in the household plumbing. Used an air compressor to break the clog free, then pumped some water into the pipe and quickly blew more air into it with the compressor so that the pressurized water could push out any clog remnants.
Everything is working perfectly, hopefully it'll be good for another 5 years!
Score 3
1 Comment:
Thank you, your advice of using compressed air worked!!
by
Add a comment
Well here is another guy struggling with same OE error code . After it came up first time (4 years after we bought the dishwasher) I checked the filter and drain hose where it connects to garbage disposer. There was a small piece of plastic stuck at the junction and filter was pretty dirty. I removed obstruction and cleaned the filter but the code kept coming up . As of now it stops the washing cycle and leaves some water on the bottom of the dishwasher. When I press normal and delicate button together the drain pump kicks in and expels the water out. So since water is coming out I don't think the drain is plugged. any more. So my next mission was to check the drain pump. Since I don't have a new pump yet I didn't feel like pulling the unit all the way out so I tried to remove the drain pump and casing from below. I took the plate off and noticed that pump is accessible. It was a challenge to work around it with very little space. To take it out I had to take off two clamp. It took me a while but I managed to do it . I used vise grip pliers to take the clamps off. The pump assembly didn't have any major obstruction aside from couple of hairs . I also checked the flap valve , it had a clear plastic piece right behind it. I thought it might be causing issues so I removed that. I hooked everything back but the code still came up. So I went online and ordered the drain pump and case (came together, pump alone is more expensive for some odd reason). I will get back to you once I try the pump. I am thinking that maybe my pump is not working as good and not expelling the water fast enough. One thing to note is that pump piece can be taken off without disconnecting hoses There is a little tab that needs to be pushed and then a little turn will remove the pump . This way you don't have to mess around with the clamps . I hope this helps those of you thinking that dishwasher has to be removed and flipped upside down for this project. Changing it from below is not easy but it saves you a lot of hassle disconnecting water supply , electricity , and moving it out. If I am 100% positive that pump is an issue maybe I would move it out but I would hate to keep disconnecting it for any other possible attempt at solving this issue. I am not entirely convinced that new pump will solve the problem but it seems to be logical next step especially since I don't have to disconnect the unit in order to replace it. If it doesn't turn out to be pump my next think to check would be whatever sensor is telling the machine that water is not draining.
Score 2
5 Comments:
As a poster here before.... who had success with the air compressor (twice) - I eventually got an OE code like you - same issue water in bottom - same would drain when force a drain at buttons. Eventually I decided it had to be the pump. Bought a new one - and replaced it - and it worked fine. Then about 3 months later the main pump (water circulation) failed.... I decided I would not throw more money after this piece of crap and I bought a Bosch... Bottom line unfortunately is that I think LG dishwasher is crap even though I paid a pretty penny. I expect your new pump will fix OE but beware of other problems.
by
Thanks for your response. At least we got good at taking things apart :) I am not impressed with LG. Our entire kitchen is LG and laundry units. Washer is still working 14 years later, dryer broke down after about 10. Kitchen is 4 years old, aside from dishwasher issues our fridge is also having minor problems. Light doesn't come on when door is open and gasket/seal around the door is cracked in couple of spots so sometimes door doesn't create very tight seal, I bought a new one but haven't installed it yet. Stainless steel stove got scratches from me trying to clean it with paper towel which might be my bad trying to scrub it too hard. I do have an LG phone that is working well :).
They just don't make anything that lasts any more. I hope that new pump will extend the life of this dishwasher a bit but I am not very confident that this will be my last battle with this device.
by
Alright so I ordered drain pump from repair clinic and it came super fast. It took me a while to confirm which pump I really need. Sears support kept suggesting wrong pump (main one) while I really needed drain pump. So I suggest being extra careful when ordering these so you are sure they send you correct one. Taking the old pump wasn't that big of a deal but for some reason I struggled for about an hour putting the new pump on. Main reason as noted in the previous comments is that there is very little space to work with. Hooking up pump to the drain hose was easy but connecting it on the other side was very difficult. There is one clamp on that side that you need to keep open/expanded (I used vise grip pliers) and than you have to slip it over the connecting hose and then you release that clam so it closes tight. I had really difficult time doing it because there is very little space to work with . If I pulled the dishwasher out and flipped it upside down it would take me 5 minutes to replace the pump but then maybe I would get stuck on something else. Since i knew it was possible to replace it from below I kept going at it until I finally connected the pump. Replacing the drain pump took care of the OE code and dishwasher seems to be working fine, I have done two loads without problems. Hopefully this is my last post about this dishwasher :) Pump I used is on the link below
https://www.repairclinic.com/PartDetail/...
by
Did the new pump fix it? I am getting the same OE error. Have some water draining out but not enough to stop the error. I’m thinking the pump might be burning out.
by
My issue ended up being a ball of tape and Halloween glitter (fun party!) stuck in the tube between the pump and drainage. There is one tube from the pump to the U shape connection on the side of the dishwasher and another tube from the U shape to the drainage. I had to disconnect the tubes from both ends and use a wet dry vac to suck and push until the tape with glitter popped out. I do not understand how it got in there since there is a filter in the dishwasher that this should have not been able to get through. If you do have some water draining out you might want to check these tubes before buying a new pump
by
Add a comment
If it's covered under warranty why are you messing with it? Let the tech fix it for free.
Score 1
4 Comments:
The tech wouldn't fix it for free. He told me it was a clogged drain line and tried to get me to pay him $269 to fix it. I ended up calling the person who installed the dishwasher and he fixed it for free.
by
I have the exact same problem at 11 months. Same thing, called warranty repair, and they gave us a local repair guy. He came out, says it's a clogged hose, and would get a new one. We aren't paying - but it has been a month now --- and still no hose, and no dishwasher! says its on back order. What, is there a run on these hoses? Maybe this should be a recall issue. I want to dump the whole thing! 15 years with my kenmore -- issue free. What is this? We are also suspecting it is a programming error with the draining... Giving false readings on the level of water, and causing it to stop prematurely. Any thoughts?
by
I have the same OE issue, I took everything apart and checked al lines are free...ot will gravity drain just fine but at the end if the cycle it just won't pump. I check ohms reading on pump and is at recommended reading about 24 ohms. I applied power to the pump and it started pumping. So i cleaned everything and tried it and nothing. Still...nothing. So another fix it forum said probably the PCB circuit board. Bought it from Repair clinic.com and that didn't work either. So without a parts and wiring diagram I'm just guessing now. Is there some other switch that tells the PCB that the water is in the bottom and tells it start draining? I see no such switches except on the fill side there are two. Just wondering if there is a correlation to these floats and telling the PCB to send voltage to the drain pump.
So if any one here is a master LG tech ot had this issue maybe you can guide me to the next trouble shooting step. Thanks for anyone's help
by
My OE code showed up right after the warranty expired (go figure). Checked all drain lines, all clear. Replaced the drain pump, still with the code. In Canada you can't order parts without going through an LG authorized repair centre (a scam). I was guessing the circuit board also at this point. I took the entire thing apart and no idea what else it could be. Frustrating to say the least especially calling LG service line. "Here's the number of the service dealer, we want nothing more to do with you since we already got your money". Buying Samsung next time.
by
Add a comment
I blew air back through my lg dishwasher and it blew the flapper plug clear out. So I had to take the bottom drain apart to put it back in. Re routed drain hose then everything worked again.
Score 1
Add a comment
Had the same 0E error. And dishwasher wouldn't drain fully. I took the hose off at the sink and drained it into a bucket a few times at the start of the cycle, so the pump and drain were working.
I read the post about pumping air from the drain end of the hose. I use a can or air (like for computers) and sealed the hose with my finger against the aircan tube, and wallah, it gurgled and bubbled back up inside the bottom of the dishwasher. did this 2 more times. Ran the dishwasher and it worked fine. May have been a coincident or dumb luck, but tried everything short of taking it apart before this.
5 Comments:
Is there a 'flapper valve' at some point from the drain to the connection to the garbage disposal? if so, what direction does it open and close? meaning if you blow air from the disposal toward the motor, the flapper valve is on the motor side.
Otherwise, if contrary, you blow compressed air from the disposal side you'd be blowing air, holding the 'flapper valve' shut. Is that right?
That make sense?
Can someone answer?
by
Oh by the way, I tried to force compressed air from what was suggested above including an air mattress pump but couldn't reproduce 'bubbling' effect. Perhaps not enough pressure. Do I need to rent and air compressor to get the desired air pressure?
by
would a garden hose do the trick?
by
I opened all the hoses and there is a rubber Flapper where the Black hose connects. I believe it is not stiff enough and will flip backwards. I can blow it with mouth and it opens the flow. The stupid pump is so week that even a small seed will cause the flapper to get stuck. This is the worst design we removed GE that was working perfectly for 20+ years to buy this fancy expensive machine. First time it clogged at month 11 and the repair man had replaced the tubing. Now I just blow in it happens every few months.
by
A big thank you to all of you. OE error light came on tonight a year after replacing the drainage impeller for £130. Thought I was going to be facing another big bill to repair. So took your advice and disconnected the drainage pipe a blew down it. Took a total of 2 minutes to do and now it's running perfectly. Thanks again.
Andy
by
Add a comment
Look beyond the drain pulll unit out and follow the drain hose up to the top. There is a small screen just between the hose couplings. Three cherry pits was all it took to block the flow enough to set off the sensor. Let me know if this solves yout problem.
Add a comment
For mine it seems to have been the small black vent hose drop the plastic piece in the middle of the drain hose to the plastic mechanism on the side of the dishwasher. I blew back through it and now it works...
Add a comment
It is possible on the display for a D to looks similar to an O. You probably have a DE error code which indicates a drain problem.
Check your drain line, make sure the drain hose is not kinked and is not blocked especially at the connection to the sink or garbage disposal. This is typically the reason that a dishwasher won't drain. Remove the hose and clear any clogs, then reinstall.
Verify that water from the sink drain is not making it's way into the dishwasher. I would recommend creating a high loop in the dishwasher drain pipe, which is attached to the sink drain below the sink. The high loop can be fastened to underneath the counter-top. This will prevent any water from entering the dishwasher from the sink; it also prevents the dishwasher drain water from making it's way back into the dishwasher.
Verify that the pumps drain impeller is working. You can reach the impeller from inside the dishwasher after removing the lower rack, spray arm and arm support. This typically involves removing a few screws. Once upper parts are removed, inspect the drain impeller (which pushes the water toward the drain port) for any cracks or missing blades. If the impeller is defective the water will not drain properly and you would need to replace it.
Verify that the drain valve is working; many are controlled with an electric solenoid that opens the valve, sending the water to the drain. There is a chance that the solenoid or the diverting lever could be stuck which would prevent the water to drain. If so, try to free up the solenoid and lubricate the lever. Otherwise the solenoid or pump assembly may have to be replaced.
Verify that the motor is turning/ working and that there is power to the motor. If the motor hums but doesn't turn, it may need to be replaced. Motors can get stuck if not used regularly. If the motor is defective, the water will not drain and you would need to replace it.
3 Comments:
There is one common denominator in these discussions...never buy LG dishwasher again .
by
I agree... I posted this issue on their web site and they removed it. The drain pump is too weak and no garbage cutter like in GE washers. So you have to rinse the dishes before you put them in.
by
Fantastic information people thanks very much. I changed out the drain pump and checked all the hoses still getting OE fault coming up then I noticed the inner filter screen was full of suds a very light film clean it with a toothbrush and everything works fine now so be sure to have a close look at the filter screen.
by
Add a comment
I tried blowing the drain pipe out with compressed air from the sink end as noted before, and it worked for me too. Thanks Jeff
Add a comment
Woke up to the OE code. Read thru all posts and here is what I did. I removed the line off the drain under sink. Removed the line off pump. And used wet dry vac on line to get all water out. Then removed the pump off machine. Again using vac to control water, as no matter what I tried I could not get it to drain, Now with pump out. I could inspect. 2 cheery pits. Seeing as we have not had cherries in 6 months I think my pump has taken a hit. Anyways. Put it all back together and first load worked fine. Thanks 4 year old LG.
Add a comment
Have same problem.Drain hose and pump motor was replaced but still show error code at the end of the cycle.No water left in dw.
1 Comment:
did you ever get it to work?
by
Add a comment
Had the OE code on my LG dishwasher and no draining checked some things finally found this site and disconnected the drain at the disposal .Plugged solid with white rice, sucked everything out with a wet vac and reconnected everything works great thank you so much for the info
Add a comment
There are not one but two “flow check valves” in my ldf6920st. One in the top of u shaped plastic tube with black hose attached. It lets a small amount of air into the pipe and will air break the hose to try to stop siphoning. Another is a one way flapper type in the “drain line “ going to disposal or sink drain. This also will try to prevent back flow. It closes shut from the sink to the pump, it’s open from the pump to the sink. These two checks “should work together to prevent water from going back into the sump. Obviously inadequate and they knew it, since installation instructions say to have airgap or high loop to do the same thing.
blowing compressed air from the sink side to the pump WILL damage the flapper and possibly push it into the pump. Just a piece of rubber waiting to plug something up.
IMO it would work just fine without it in there.
I got into mine because the hose failed and destroyed my oak floor. That hose is junk! Nowhere in the owners manual does it say to replace the hose as part of a maintenance plan. But if you dig around enough you can find where lg does say it to the tech.
i hope mine works again and the water goes where it supposed to, the squealing stops, the sump drains, and dishes are clean after I removed three pieces of plastic from various places inside. All of which came from it but I have no idea where. Possibly there from day one out of assembly plant. A check valve on drain pump was broken and jammed the pump. Plastic pieces plugging drain lines. Shaft seal leaking. no food at all plugging up any thing, it was very clean inside.
Al in all I highly recommend a Bosh or Kitchen Aid or something other than LG. NEVER AGAIN FOR ME.
washing by hand always works and doesn’t need a tech.
Add a comment
I have an LG dishwasher since 2013 and it worked with no issues. Recently, June 2019, I got the OE error and could not get rid of it. I called LG for a recommended repair person in my area. I called the repair person and they came and said the drain pump was bad. He replaced the drain pump and it worked for two weeks then the OE error came back. I called the repair person and could not get him to come back and check why this error is back. So I called LG again and asked for a LG trained technician. They sent a technician and before he came to my house he ordered a new drain pump. When he got to my house he pulled the drain line from the disposal and turn on the dishwasher and it pumped out water. He said it is not the pump it is the control board. He ordered a control board and came back to install it. When he was done he turned on the dishwasher after running for a while the OE error was back. He left before the cycle was completed. I called him and he said the drain line is too low. None of these technicians did any troubleshooting. All they did is change parts. I decided to try and troubleshoot myself. So check this forum and found suggestions to solve the problem. What I did was use my shopvac to suck out the drain line from the end going into the disposal. It sucked out a lot of sediment from over the years in the drain line. After I using the shopvac I turned on the dishwasher and it has worked without any issues since. These technicians only know to change parts and not think through possible solutions. I suspect my dishwasher never needed a new drain pump or a new control board. All that was needed to to clean out the drain line.
Add a comment
Got the dreaded problem draining code too. Just over a yr old. Did the compressed air thing. No luck. It started only having code on Heavy cycle so we used other cycles. Eventually it gave code on all of them. But you could force it to drain. Some. Just put on new pump. Still drain code. I’m betting something electronic. Going to try to drain into bucket test soon with new pump but I bet it’s fine. LG must really stand for “Looks Good” but that’s about it. Won’t buy any of their products again!
2 Comments:
You need to change the hose with the 180 degree plastic bend in it.
by
Pull the unit out of its enclosure. Check the sump near the pump and
then the entire discharge path. I my case a few lemon seeds clogged the plastic vacuum breaker fitting high up on the left side.
by
Add a comment
I had the OE error as well on model LDF7561ST.
The motor would try to empty the water from the machine but it didn't sound normal when listening from the sink drain. Not the usual rush of water, then the OE error.
I could force it to finish draining by using the diagnostic mode (from standby - press power, then normal, then Delicate + Normal together for 3 seconds) so I wasn't sure if the motor was bad.
I did the things mentioned by others and from the service sheet that came with our unit:
- ensure the drain hose is clear
- ensure the sink drain connection is clear
- checked the motor resistance is between 4 and 5 ohms
I bought a replacement drain motor and noticed right away that the new motor does not allow the impeller to spin freely and the old one did.
It has been in use for a few weeks now with no signs of trouble.
Add a comment
After months of messing with this issue
I loosened the clamp that holds the drain hose on the side out the disposal outlet .
the pipe that came with the kit was long enough that I got the end over to kitchen faucet spout and blew water pressure backwards through the system .
You could see debris bubbling up in the dishwasher bottom under the water arm .
It ran for approx 30-45 seconds .
I reattached the drain hose , pushed power ,And held the start button down til it cancelled out the last wash cycle and started to drain .
When it finished draining I restarted it .
as it cycled your could hear a loud gurgling sound where I believe the flapper (check valve ) going back through the line was blow back the other direction by the water pressure I forced through the hose .
eventually the gurgling went away when the check valve flapper reset itself .
I have to repeat this procedure every few months to rid the machine of the slightest debris .
In the end this LG dishwasher is a $700 piece of excrement , that doesn’t like washing dirty dishes , it only wants to wash clean dishes .
I had a $199 Whirlpool stripped down model in my last residence that BLASTED hot water everywhere and got the dishes spotless .
This LG unit runs on a quart of water and doesn’t perform half as well ,
it’s a crappy design , unless you enjoy scrubbing your dishes before putting them in the LG !
Mike R
1 Comment:
Back-washing the drain line with tap water or compressed air (though i reccomend no more than 30psi) always seems to do the trick! I cant imagine that it's good for the check valve(s) that are in there but this has worked on several LG dish washers at a price tag of $0 and in about 5minutes. Obviously check for clogged traps/screens, bent hoses/ or general blockages first as that is the problem most of the time.
by
Add a comment
Is putting a cherry pit in your dishwasher a British thing? I recommend not putting cherry pits in the dishwasher.
Score -1
Add a comment
Add your answer
Brian will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 68
Past 30 Days: 288
All Time: 183,951
