Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
Lost screws, can not find replacement
Hi
I kept an ipad mini in for a repair couple of months ago for an LCD but customer didn't have the money straight away, so broke the ipad down so all I had to do was put the thing back together.
I put the LCD x4 & Plate screws in a sealed sandwhich bag......and I can't find it!!!!
I've taken the kitchen cupboards off the wall thinking the bag fell down the back but nothing!
I can find screws for every ipad apart from the Mini (i'm in the UK)
Is there anything else compatible to use?
Thanks
Score 1
Add a comment
Most Helpful Answer
You mean the four 3.9 mm Phillips #00 screws securing the LCD to the rear case? Try other repair shops or hardware stores in your area.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
i have hunted these screws many times---extremely difficult to find in the marketplace.
When I'm forced to make a substitute, I use the iPad 1 LCD screws, and I try to just substitute 1 on several different minis until I can use three original and 1 iPad 1 screw.
1 Comment:
Are all screw necessary when replacing the antenna or is it okay if I'm missing one?
by
Add a comment
Add your answer
Duane will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,003
