2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Question Closed
replaced logic board, and still no power
Greetings, I just replaced the logic board in my Macbook with a used, supposedly working board, and put it back together properly, and no power. Mag safe adapter is orange when attached. What is the most likely problem here assuming that the board is good? Power switch bad? If so, can I test it somehow? Or something else? Any info will be appreciated.
Thanks, David
Add a comment
Chosen Solution
I would try replacing the MagSafe board. Its possible the connector is bad.
Are you sure the logic board is good?
Score 2
Add a comment
See this previous Question and Answer.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 106
