Repair information and guides for the fifth generation of iPhone. Model: A1387
2191 Questions View all
Question Closed
Replaced the battery as described, but still not working
Hi community,
I've replaced the battery as described (worked very well) but still I cannot turn the iPhone on. The switch seems to work (if I connect the phone to the charger or to the laptop) but it seems, that the battery won't get charged.
I always get a prompt to restore a firmware image but I cannot restore the image. Doing so will always fail (during the first reboot after preparation) with error 21 (unknown error).
Any suggestions?
Thanks for your feedback - best regards...
Add a comment
Install a battery with charge on it see does the iPhone boot
Then when it boots see does the % increase if it doesn't then a dock replacement is needed
Sometimes a faulty dock will say it's charhing when it's not even
1 Comment:
Hi,
thanks for your answer, how can I replace a "charged" battery or - asking another way - how can I charge the battery without an iPhone attached to it ;)
Unfortunately the iPhone is in a "unrecognized" state which means I am not sure which firmware (or even if a firmware) is running. I cannot "repair" the iphone without being sure, that the battery is "full".
Any ideas?
by
Add a comment
Ok if you have a friend with a iPhone 4s and it's got battery life take the battery out of it and install in yours .. Simple
1 Comment:
Hi,
would be even easier if I had a friend using this "old" phone anymore. I don't know whether the battery has any battery protection circuit or anything like that, than I'd just attach it to my LiIon charger - I "could" do that if anyone could point out the pinnig of the connector. If the charging logic is not within the battery itself this could just blow up the battery... bad idea...
I wonder whether I could charge the battery inside a iPhone 4?
Any other ideas?
Thanks and best regards,
Sven
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 105
