Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Wifi says searching and won't connect.
After replacing the screen, I had a couple of pieces left over. Once I figured out where to put these pieces, the section for wifi continuously says "searching". The wifi was working prior to screen replacement. Any ideas on how I can fix this?
Score 1
Add a comment
1 Answer
So to settings general then reset and reset network settings then after this try to connect to wifi again. Also make sure you have the wifi connector plugged in correctly it's the little connector just to the right of the lcd connector
Update
Wifi connector is under that left screw in red box
Add a comment
Add your answer
Danielle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 222
