2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Jumpstart and keyboard, trackpad works but power button does not
My Macbook Pro's (early 2008, 2.4 GHz model A1260 Core 2 Duo) power button is not responding at all. I managed to power it on by shorting the power pins on the motherboard. The keyboard, track pad, etc all are working fine and I am typing this question from the same laptop.
If it can be fixed inexpensively by changing just the power button and its associated circuitry, does anyone have a detailed instructions for that? Or do I need to change the entire top case?
I have cleaned out the dust inside when I opened the top case. This was not caused by any liquid spill. Was working fine till yesterday. I have gone through all the suggested fixes from SMC reset to using only AC or battery power, etc. but none has helped.
Add a comment
1 Answer
Chosen Solution
You'll need to trace out the two red wires from the power button on the upper case unit with an Ohm meter. Either the button its self is bad or the connection to the ribbon cable in the upper case is bad.
Score 1
Add a comment
Add your answer
Choosy One will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 202
